Hi guys, this is the situation. Pushing in the lever to get the washer pump to work yeilds nothing. The wipers work fine though.
Took the washer res out of the car, tested pump with 12volts and the pump works fine.
With volt meter, tested connector, nothing. Stripped some insulation from wires , tested with volt meter, nothing.
I believe that the wipers are on the same fuse as the washers so thats not the prob.
Tried to disassemble column but ran into roadblocks:
Tried to take the plastic cover off but it won't come off until you remove the cruise lever, but can't unscrew lever because there is a wire attaced to it.
Can someone help me from this point PLEASE :}
Matt
Matt
