While the engine is cold and running, there is coolant comming out at the bottom of the radiator. near the drain plug. i can't see exactly where.
when the engine is warmed up after 10 minutes (thermostat open?) the leaking stops..
i got this for the last month or so, every day the same story. anyone had the same problem ? what sould i do / check?
if leaking from the draincock area check for loose hose clamp or split hose, Also check for busted oring or loose draincock. Could also be leaking from radiator fins and draining to that area.
IF possible get a pressure tester and chacl to see where leaking when cold, check front and back fins and where the fins attach to the side tanks.
