Every time it's humid and I have my A/C on, the passenger side carpet gets wet. I'm assuming this is a condensation problem. If it is, can anyone help me in locating the drain line.
Welcome to DC!
Alot of years to consider.. I'm not entirely certain all the drain lines are in the same location..
May we have the year and model (Vert/Coupe/FRC)?
TIA,
D
RK3442 said:
99WhiteC5Cpe......thanks for the link. Exactly what I was looking for. Thanks again.
You are welcome.
I am very familiar with this problem. If you have any problems or questions, please email me and I will try to help you.
Good luck again.
A/C Drain Plug 101
A/C drains next to the battery tray, through the firewall.
Best to work from underneath (on a lift/jackstands).
The rubber elbow pulls off and can be clogged with debris. Since it is a common issue that can result in water getting into and damaging the electronics, it should be routinely done with under the car maintenance.
C'ya
D
