Ok,just about to fit a new engine.
Couple of small issues,
No provision for oil pressure sender by oil filter so fitted it at back of block by dizzy(easy fix).
No provision for water temp sender between 1&3 cylinder on heads,so where do i fit sender for accurate reading.
If i fit it on stat housing will it only read when stat is open?
Any where else on block/inlet manifold or water pump it can be fitted?
Any ideas?
Any ideas?
