ways to turn over the engine WITHOUT the starter
theres large bolts for your ballancer
theres crank sockets
Crankshaft Socket Tool For turning AND MOUNTING Degree Wheels
CRANK NUTS
crank rotaters
flywheel turning tools
and your going to need at least one when you degree in a cam or do a compression or leakdown test
no just 33 years building engines and at least 150 plus engines built (I LOST COUNT YEARS AGO)
but I can help by saying that youll be way ahead of the curve by buying and reading a few books that were not available when I started building engines
and take the time to READ ALL THE POSTS IN THE c-4 FACTS sections
here read these also
http://www.grapeaperacing.com/GrapeApeRacing/tech/miscmachine.cfm
http://www.dragtips.com/articles/drag_racing-15.html
http://members.aol.com/kstegath/articles/383.htm
http://www.73-87.com/chp/chp.htm
http://chevyhiperformance.com/techarticles/71298/index.html
http://www.sa-motorsports.com/diyport.htm
http://www.ws6transam.org/ported.html
http://www.hotrod.com/editorial/article.jsp?id=869
http://www.zianet.com/v8monza/engine.htm
http://www.findarticles.com/cf_0/m1....jhtml?term=chevy++combustion++chamber+design
http://www.speedomotive.com/building tips.htm
http://www.aros.net/~rbuck/chp/Welcome.html
http://www.sa-motorsports.com/blockdiy/blkdiy.htm
http://www.ryanscarpage.50megs.com/combos1.html
DO YOURSELF A BIG FAVOR
buy these FIVE books, FIRST it will be the best money you ever spent, read them, and you will be miles ahead of the average guy. youll save hundreds of dollars and thousands of hours once youve got a good basic understanding of what your trying to do!
HOW TO BUILD THE SMALL BLOCK CHEVEROLET by LARRY ATHERTON&LARRY SCHREIB
HOW TO BUILD MAX PERFORMANCE CHEVY SMALL BLOCKS ON A BUDGET by DAVID VIZARD
JOHN LINGENFELTER on modifying small-block chevy engines
how to build & modify CHEVROLET small-block V-8 CAMSHAFTS & VALVTRAINS BY DAVID VIZARD
SMOKEY YUNICK,S POWER SECRETS
youll cut years off the time you spend learning by trial and error!
