one thing I learned long ago... ask questions, you'll be amazed at what other people know that you might not know,
or remember.
Ive got a guy in my shop that has zero brake fluid pressure on the pass side front brake caliper feed line
there does not appear to be anything wrong with the master cylinder as the drivers side front brake works fine
and if I bleed the brake theres zero fluid pressure reaching the pass front brake, there appears to be no line damage so the brake
modulator valve,behind the divers seat looks to be defective? or some pressure sensor or perhaps a fuse is blown?
I posted a link to an ABS manual. That might be of help. I also have a GM training manual coming from eBay. Line from wheel back been checked for any damage?
Disconnect line at ABS/modulator and see if pressure there.
Where did you check pressure at the wheel? Caliper, flex line or solid line or all three?
