As long as you go with a quality Dexron III fluid, you should be fine. I'm partial to Mobil 1, but I've had good luck with Amsoil and Royal Purple as well.
What kind of automatic transmission fluid should you use in your transmission? The type specified in your owner's manual or printed on the transmission dipstick.
For older Ford automatics and certain imports, Type "F" is usually required. Most Fords since the 1980s require "Mercon" fluid, which is Ford's equivalent of Dexron II.
For General Motors, Chrysler and other imports, Dexron II is usually specified.
NOTE: Some newer vehicles with electronically-controlled transmissions require Dexron IIe or Dexron III fluid. GM says its new long-life Dexron III fluid can be substituted for Dexron II in older vehicle applications.
CAUTION: Using the wrong type of fluid can affect the way the transmission shifts and feels. Using Type F fluid in an application that calls for Dexron II may make the transmission shift too harshly. Using Dexron II in a transmission that requires Type F may allow the transmission to slip under heavy load, which can accelerate clutch wear.
read this
http://forum.grumpysperformance.com/viewtopic.php?f=71&t=4909
http://forum.grumpysperformance.com/viewtopic.php?f=71&t=4910
http://forum.grumpysperformance.com/viewtopic.php?f=71&t=662
