Once again, "Hawaiian Punch"
Howzit and Aloha!
I was wondering, since I put a 52 throttle body on my car last night (Mahalo to a buddy of mine here in Hawaii) what kind of gains should I expect to get?
I never ran with it at the track obviously, in fact, I havent even driven it yet, bout time I installed it, it was around 11:15 p.m, to late to do some testing.
I have done the usual air intake and exaust mod's like, cut air filter thing, ported plenum, intake manifold, saimiesed runner's, 1.6 rollers, gutted all the cat's with no mufflers on the car, changed to 3.07 rear end from the 2.59, relocated air temp sensor, smog pump removal, Ed wright custom race chip, programed the fans to turn on at 160* with a 160 thermal stat, and now the 52 mil throttle body... hhmmmm..... I think that just about does it for the mod's.
So once agin I ask, what kind of gains should I be expecting with the edition of the throttle body?
I have a '91 L-98 vette.
your potential gains if any will depend on how badly the stock 48mm throttle body was restricting the engines airflow before the swap,it the TPI INTAKE and CYLINDER HEADS NOT the throttle body thats the big resrtiction take the time to read the links
http://www.eecis.udel.edu/~davis/z28/winter01/dyno/dyno021105/webpage021105.html
http://www.crossedflags.com/community/viewtopic.php?t=2447
http://www.crossedflags.com/community/viewtopic.php?p=4334#4334
http://www.crossedflags.com/community/viewtopic.php?t=2561
http://www.geocities.com/jgkov/L98Mods.html
pictures you might want to look at
http://www.ws6.com/mycar.htm
a CUSTOM PLENUM HOLLEY STEALTH RAM,CAM and CYLINDER HEADS SWAP will make a HUGE differance in the corvettes hp
HERES ANOTHER CORVETTE WITH THE CUSTOM STEALTH RAM INSTALLED
a CUSTOM PLENUM HOLLEY STEALTH RAM,CAM and CYLINDER HEADS SWAP will make a HUGE differance in the corvettes hp , FAR EXCEEDING ANYTHING YOU CAN DO TO A STOCK TPI STYLE INTAKE, GAINS IN FLOW OF 20-30cfm by porting a STOCK TPI are hard to get, a CUSTOM STEALTH RAM flows 75cfm better out of the box -100cfm PLUS better with minor port work! a complete STEALTH RAM with custom plenum out flows them all out of the box EMAIL ME FOR DETAILS
