Does the C6 allow for slightly larger tires in the rear than the stock 285's? Has anyone put 295's on them like the previous Z06?
you can go to tire rack. they have a chart for each tire. it will give you the parameters. i have the wide oval rft's and they list that they will actually fit a 295 on the 10" wheel.
now, you can go several sizes over. the tire will actually go on the wheel. but you may get a crowning effect. the side will be all goofy aswell.
so, go check out the chart on tire rack.
actually if you look a few posts down there is a picture of the 325's on somebody's coupe...
look for the thread with this title:
19X10 front and 20X11 rear
Thanks a bunch for the lead. When these tires are bare, I plan to get new wheels and hopefully wider tires so as to get better grip, now that I'm pushing 520hp at the flywheel. takes nothing to lose grip on my c6 with this kind of power!
