1 - 12 of 12 Posts
Hey guys how wide can I go with the car dropped 1 inch and a 19X10 rim width. Its a stock 98 c5 6 speed no tubbing.
Question: Did the aftermarket wheels come with the car when you bought it, or did you put them on? A 10'' is preety skinny.
rear tires
I have been trying to find this out my self I have 10.5 wide rims (cray) and would like to put more meat on the ground.But don't want any more hight I now have 275x40x18 any clue ?
Non runflat rear 305/30-19 on 19 x 11 rims, no tubbing. I get some lite sidewall rub on twisty roads with tire sidewall flex...........
Fronts are non runflat 275/35-18 on 18 x 9.5
Can't get any wider under the fenders. Don't believe you could put this size (305) tire on a 10" rim. You probably are looking at 285 or 295 max. If even that wide. 10" is pretty narrow.
actully the 10" was a typo its actuly 19X11 Deep dish aftermarket Z06 I have 275 on there now, 305 to 315 should fit correct?
You can always go back and edit your post. Yes a 305 depending on manufacturer, will fit after you lower the car.:laughing:
There is less than 1/8" inside clearance to sidewall with proper backspace wheel.
Go with a 305. :partyon:
You're running a too tall tire already (40 series) :surprised, go 295/35, or 305 no problem. It all depends on your offset.
No help here... I am currently testing to see the widest rear I can run on my tires. :laughing:
Damn Dominos!
1 - 12 of 12 Posts
