1 - 8 of 8 Posts
Greeting Fellow Corvetter ...
I just purchased a 2003 C-5 to go with my 1974 C-3.
The question here is do I disconnect the battery? Or leave it connected?
Non heated garage.
Would like feedback.
Thanks for the info ...
Bump
Do you plan on starting it over the winter or just leaving it until spring?
I store mine in an unheated barn for the winter and I just remove the negative cable. Come back in May reconnect the cable and the car has started without a problem every year for 4 years now.
I charge mine. Plenty of "smart" maintenance charges out there that monitor the battery and only charge when needed. While I don't have one, "Battery Tender" comes to mind as a good choice.
Discussion Starter #5
Thanks for the replys
I want to Thank all my fellow Corvetter's for their responce back to my question.
I did manage to pick up a CTEK battery charger, and will charge the battery over the winter slumber.
Thanks Again All
:laughing: why not drive it, hahaha good one. :smack
I remove the battery and clean the battery and compartment then I just put a smart chrger on it.
Thanks Again All
:thumbsup: I'm glad you solved your problem.
1 - 8 of 8 Posts
