I think I have an issue with the windshield wipers on my 91. Here is what it does:
1. When I move the control knob to mist I get the spray of cleaner but the wipers don't move, although I do hear a noise coming from the wiper motor that sounds like a connection is occuring but no wiper movement - even when I continually hold the lever in the mist position
2. When I turn the wipers from off to high they work ok but seem a bit sluggish. They will work when going from high to low and then to the delay settings, but again the motor seems weak.
3. If I turn the control knob from off to the any of the delay indents I can hear the same click noise coming from the wiper motor, but in most cases I get no wiper movement.
4. When operating the wipers they rarely return to their off position and remain stuck at whatever position they were in when I turned the control knob to off. I haVE to work the control knob to get it to a point where I can get the wipers to settle into their resting position
So, it sounds like it may be the motor, but wanted to get your opinions.
Thanks, Mark
does sound like motor
sounds like you have voltage but sounds like motor is shot. if you have a volt meter i would check to see that you are getting 12 v to the motor. also see if power plug is corroded a voltage drop might cause it, but its unlikely... sorry bro. sweet car though.
