I have a 2006 Z06 ,In December 2006 my Z06 was outside in freezing temp. when I returned to my car the passenger side door would not open. It eventually reset once it got warmer. These are the symptoms, and they still exist . When I get in my car in the morning(garaged & not freezing)the red light is blinking on the door,the window is partially down, as if the door started the opening sequence by itself. The door will not open ,and it eventually resets after some time. I have taken it to my local dealer maybe 4 times , and they've said they repaired the problem each time, only for it to reoccur. Has anyone had this same problem? If yes ,please help. Should I take this isssue to another level, since my local dealer cant correct it ?
