Was wondering if the steering column is supposed to be able to wiggle up and down when you push on it?
It is not suppose to, but with age and wear it will occur. You might do a search over on the ZR1.net registry and there may be an answer for the problem or someone that might chime in to assist. I have the same issue with my '92 ZR-1.
Good luck!
The bolts could be loose. You have to remove the steering wheel and will need a tool to compress the spring and remove the c clip. Dont try to remove the c-clip without the tool. It is a easy job with the correct tools.
