Need to wire the fuel pump relay for the 454 swap,where is the best place to wire the relay into? Anybody have a pic of linkage hooked up with the 4 speed with overdrive .
If you haven't butchered the wiring up you still have everything needed in place.Need to wire the fuel pump relay for the 454 swap,where is the best place to wire the relay into?
Get one from an early S-10 truckNeed wiper motor to replace the oversize stock one ,have the bbc mounted,trying to finish up the little [big] thing's that go alonge with a bbc swap.
How do you want to do it?Need simple sketch on how to wire fuel pump , gutted wiring in engine bay ..
Going to need a lot more detail to identify random wires like where they originate fromFound two red wires on pass side floor also red,green,white and another red wire going under door seal . .
