C6 Z06 Cam only with LG Headers dyno results
1 reading
10K views 23 replies 14 participants last post by  SuperSportTr
#1 · (Edited)
First, as you all know, this is with NO TUNING.
We just did the dyno pulls with our New G7X-2 experimental Cam. We have some work to do on some details on the cam to get the torque up a bit. But here is the graph of todays run, with just a cam, LG Pro Long Tube Headers, and air filter out.
540 rwhp 489 rwtq
This is our second cam we tried, so it will be our G7X-2 exp until we finalize our X2 profile.
The car is a beast to say the least, and it still idles like a mild high performance cam at 650 rpm (stock rpm)
Thanks and feel free to ask any questions other than cam specs and my wife's age.
Thanks
Lou Gigliotti LGM
THE VIDEO of G7X-2 cam, LG Headers, Exh bypass switch demo
www.lgmracing.com/lgm-c6zo6-ebs.wmv
Before and after. dyno from stock new vs LG Cam & LG headers
#3 ·
Hi,
This is only our first itteration of our G7X-2 cam, thus the experimental designation.
in fact the torque did increase about 70 ft pounds, just not in the area that we want it.
You will also notice that the torque at 3000 rpms is 416 ft pounds Rear wheel. That is almost as much as the peak torque of the stock Z06.
Horsepower=Torque x RPM divided by 5250.
It is all in our cam right now. When we adjust some details on the cam, we will pull the torque up at the lower rpms for sure.
ANd there is no tuning, so the A/F was lean at peak torque, so that pulls the numbers down also.
remember this is only our 2nd cam. Stay tuned!
Thanks
Lou G
PS, Keep in mind it has over 70 rwtq more than stock, and it has nearly 100 hp more than the stock Z06. I would not say that is a problem yet. :)
#9 ·
This is still a relatively small cam. We did change the springs to facilitate larger cams for our testing.
The first cam we tried did use stock springs and it made 505rwhp.
We didn't want to find the limit of the springs in a bad way, so we put good springs in, with lots of room to grow.
As for 600rwhp? well, when the first LS6 came out in 2001 and cars were hitting 350 rwhp stock, the plateau was set at 500 rwhp N/A. To this date, only a handful of N/A stock cu in LS 6 engines have hit the magic 500rwhp.
I will expect that the same will happen here. There will be a few cars that hit 600 rwhp or better N/A with a stock 7 liter build up.
Thanks
Lou G
#11 ·
#21 ·
kamikazi said:
I doubt you've checked at this point, but do you expect this to be a street cam or offroad? Thanks Lou! Those are some awesome numbers and amazing sound! It'll be a few months before I have my Z, but we'll be talking, I'm sure.
This is still a very small cam compared to our regular 7 liter cams from the past. The heads are the amazing part.
I plan on taking it to the emission test place nearby to see what the car does on the sniffer.
These numbers are with cats installed, wich is also amazing.
Great car.
LG
#23 ·
lehmannhenry said:
That's true up to a point. The exaust needs a lot more flow to gain power. Refer to this thread here
RIGHT- Lou is saying, he expects 625 to 640bhp at the flywheel, W/OUT HEAD WORK, which is all I am saying in my post if that is, one does not want more than around 640bhp at the flywheel.
So, I am guessing your point is, that you want more HP than the possible 625 to 640bhp at the flywheel, Lou spoke of getting with the stock heads.
My point in saying, "Head work will not be necessary, the stock heads deliver massive flow." that you may have missed was only that something in the 600+ BHP range one can get from factory heads is a lot of enexpensive HorsePower waiting for any driver to tap into.
#24 ·
427 C6 said:
Thanks for all the info Lou!
What are your thoughts on dropping the LS7 heads and intake on top of a LS2 bottom end in a 06 coupe with your cam and headers.
Do you think the 6.0 bore is large enough for the LS7 heads?
Thanks for any info.
As far as i know the minimum bore you can put a LS7 head on is 4.060, so i don't think you would be able too
