With the engine sitting behind the driver, in front of the transmission, Jalopnik thinks the manual (3 pedal) will not be available in the C8. They - and apparently Car & Driver - think that Tremec's new 7 speed dual clutch tranny will be the tranny of choice in the C8. The new Tremec promises paddle shifts faster than the current C7 8spd auto.
Tremec engineering documents show a 9000-rpm maximum input speed and a 664-lb-ft torque capacity, both of which should cover C8 Corvette needs quite nicely. The TR-9007’s die-cast aluminum housing contains seven forward gears, three of which are overdrive ratios, and a 5.6:1 ratio spread. Tremec describes the twin engagement devices as “virtually dry wet clutches.”
This is not exactly a Nostradamus-type prediction. If you look at the current list of serious Mid-engine sports cars out there, all of them offer a clutchless transmission and VERY few (only one?) offers a manual transmission.
I just hope they don't put in one of those little pencil lead, 3 inch gear selectors like the first paddle shift Ferraris.
Not from Jalopnik: Latest rumor says GM /Ford are working together on a 10 spd Auto (most likely to be used in trucks - at least) that could find its way into the C8 as an alternative to the Dual Clutch tranny.
