content removed.
Hard for me to comment on another job as I don't know how it was done. I can guess, and that would be it was a stock setup. All the diff I do I have to grindthe yokes faces to set the endplay to between .005-.010" max. With a stock posi setup .030 is about what you will see. As Mike said they can be all over the place and I've had some new and rebuilt yoke come in that were not machines correctly and were way off. In your case I would ask the guys who did the job how they did it and what the spec's were on it.thanks for your time, you've been a big help... one more question please. How much endplay should I accept before I go back to the place that put a rear in my car for $2500, and tell them they goofed? I put 1k to 1.5k miles on it since it was done in aug, 07.
Ryan,Gary,
How do you feel about button welds on tips of the side yokes and ground down on side yokes that are too short and the person doesn't want to spend the cash t fix it correctly?
gtr1999; What I have not seen is a good fix for the housing once the yke grinds it down into the seal said:That's my next project as soon as I get caught up on other work.
Mike
Tips...TIPS?!! Where are my tips?!:huh:Here something to check with rebuilt yokes, and I'll post this on the rebuild post as well.
I had some come in that were rebuild poorly and the splines didn't line up. Now most of the time this doesn't happen but if you're like me and buy parts to use in a year or more then look at them when you get them.
Here is the end of the yoke. You can see the tip is not aligned and this would not fit in the side gear unless it was hammered in. Maybe some do that as well:surprised
