Hey Gary
Hi from a former New Britain, CT resident.
Great tech and photos on the trailing arms. I have not yet bought the new bushings, but plan on using rubber. I am knee deep in a full restoration and have repalced all the bushings with rubber.
When I look at your thread, the uncompressed dimension for the trailing arms appears to be approx 2-3/8". As one end of the sleeve appears to be already flared, I assume that you assemble into the trailing arm and compress the other side of the sleeve to flare it. As Steve stated, how far do you compress? Once compressed, did you grind smooth the face of the flared end so it left no rough edges?
Also, the tool looks fairly easy to make, but what does the inside portion look like that actually does the flaring of the sleeve. Every on-line tool I have looked at requires a press to make the flare, it looks like you utilze the 2 bolts tightened simotaniously to flare.
Also, the 2 places I got costs from wanted over $80.00 for each arm plus the cost of the bushings.
Thanks again
Mark
