Parking lights on, headlight up and off?
2.2K views 8 replies 4 participants last post by  dylan 93z
#1 ·
I thought the parking lights were not supposed to raise the headlights but when I trun just the parking lights on the headlights pop up but they do not come on until I actually tirn them on...
#2 ·
Dylan you are correct that is not normal operation....sounds like you "probably" need a headlight actuator control module.....they run anywhere from $80-180 and you could install it yourself with minimal tools and moderate technical ability if you felt like "shotgunning it" or I'd recommend seeking a dealer or other qualified technician to take a look at the system:thumbsup:
#6 ·
On my car:
If you turn on the headlights first so that they pop up and then turn the knob back to parking lights, the headlights will turn off but they do not pop down.
I know that this is not the answer to your problem, but maybe it is useful to know when you do the fault finding...
Maybe the problem is in the switch?
#7 ·
mine reacts the same in the fact the headlights will remain up after they have been turned on then back off with the parking lights on, its just the headlights come on with the parking lights initially switched on.
i will install the new headlight gear and see if that works and if so then i will know this is yet another indication of the gear problem.
