I got my set of 6 spicers, the half shaft ones went in easy, but the driveshaft ones do not fit.
when i pressed the caps on, i could not get one of them to go in far enough for the snap rings to go on. both of the u joints on the driveshaft front and rear cracked the plastic rings. the first one i over tightened way too much, so that was my fault, but the second one had one cap all the way against the the snap ring, and the other snap ring was barely too thick to fit in. can i buy new plastic rings or do i have to buy whole new joints?
it seems like the driveshaft is not wide enough for the cap to fit in with snap rings, like it was bent inward even though the journals are both parallel to each other.
